engine misfiring
Old 03-15-2012 | 03:01 PM
britcanmp's Avatar
Default engine misfiring
it was running badly and getting 8MPG. OBD2 said check spark plugs... removed panel in front of windshield ,. changed plugs and ignition wires. was better but later warning lights on again. OBD2 said wires and plugs causing misfire on # 1 cylinder. off came panel under the hood in front of windshield. not too hard secong time around checked wires and plugs all O>K Then I replaced the coil unit its a one piece unit priced at $69. not bad now 3 weeks later it is still running great mileage ar 16MPG .hope this is helpful to someone else.
Old 03-15-2012 | 03:08 PM
Thank you for sharing that info with us !
Old 03-18-2012 | 02:26 PM
cjhutchy's Avatar
Default need help with removing windsheild thing!!
So i noticed i cant get at the back plugs and the front is hard enough, how do you remove that windshield thingy?
im getting missing in the engine, bouncy!! probably never been done at 190,000 kms!!
Old 03-30-2012 | 05:35 PM
jmarple's Avatar
Default Removing wiper tray and windshield shroud
Its not too tough, you remove the 8-10 screws on the plastic piece under the rear of the hood after removing the passenger-side wiper blade arm. Once that is off, you remove the windshield shroud that is underneath. It has a few screws and snap-in points, and you have to unplug the two windshiield washer hoses as well as unplugging the windshield wiper motor. LOL.. maybe I have the two operations reversed, but either way, it is pretty easy, just takes about 20 minutes ;-)
Old 04-02-2012 | 07:52 AM
Use Common Sense's Avatar
Just remenber to re-connect the wiper motor wiring harnes when re-installing the cowl. Been there, forgot that...
Had that..."Great, now what's up with the wipers"...Then the "What an idiot" moment...
britcanmp
03-15-2012 03:00 PM
nickbertozzi
09-28-2010 10:30 AM
SKHAIRCORP
08-08-2005 07:06 PM
SKHAIRCORP
08-08-2005 07:06 PM
dbone420
06-24-2005 01:52 PM
