Power window problem
Old 12-02-2011 | 01:44 PM
designsngold's Avatar
Default Power window problem
2004 Ford Freestar van. The power window, drivers side will not work. When I try to lower window all I hear is a "click". Is this something I can fix or do I have to take it to the dealer.
Old 12-05-2011 | 08:31 AM
Use Common Sense's Avatar
Could be the power window motor, or the window drive system is hanging up. I would remove the panel and check for voltage to the motor. If no voltage, it just may be the switch. Even though the switch is mounted into a switch cluster under the panel, I believe that the switches are still individually replaceable so that you don't have to purchase the whole switch cluster.
robert1958
07-29-2011 08:19 PM
ppeabody
03-31-2008 07:30 PM
chaka
08-20-2007 01:27 PM
eoreillyfordranger
01-10-2007 03:35 PM
Auburn
07-20-2005 12:19 AM
