Radiator fan stuck what to do
Old 03-15-2013 | 09:07 PM
FAUSTOCG's Avatar
Default Radiator fan stuck what to do
I just bought a 2006 mercury monterey and just realized that one of the radiators fans is hard stuck a tried to push it with my hands but runs and stucks again so Im going to buy new fans but want to know what is best to unplug this fan or to keep it plug I dont know how long this problems has been and dont want to fry any electronics by keeping plug or unpluged what should I do need to drive it to get it fixed.
Thank you.
Old 03-16-2013 | 05:25 PM
grindman's Avatar
does the engine get hot when you're stopped at a red light and then cools back down while in motion or does it get to normal and stay there?
Old 03-18-2013 | 03:08 PM
FAUSTOCG's Avatar
Hi the temperature needle is alway on the center when moving or stop
Old 03-18-2013 | 06:15 PM
grindman's Avatar
the one that's stuck or sticks is for the air conditioning that one I don't think it will hurt any thing to leave unplugged but if the engine gets above normal then plug it back in
Old 03-19-2013 | 03:49 PM
FAUSTOCG's Avatar
Default thank you
thank you very much for your help I just hope that the damaged fan did not fried any electronics. Fans arrived today maybe tomorrow I will have them install.
Best regards
Old 03-25-2013 | 01:09 AM
FAUSTOCG's Avatar
Default Radiator fan update
Hi just to let you know that new radiator fans are installed now and working OK I took the monterey to someone who remove all connectors and cables from the top also air filter and battery holder swing a little bit the fan and took it out with out removing radiator or transmission lines hope this helps someone else, may not be by the book but it worked.
Thank you for all your help
factory310
04-28-2007 07:23 PM
fairstang1
11-13-2006 03:32 AM
daveranger
10-31-2006 05:54 AM
mr2 in nl
07-30-2006 02:41 AM
daveranger
07-08-2006 08:42 PM
