2006 fusion sunroof
Old 06-29-2009 | 10:50 AM
Capt33708's Avatar
Question 2006 fusion sunroof
The sunroof on my 2006 fusion does not close flush with the roof. It is about 1/2 inch below the roof line. I tried loosening the back torx screws and pushing the glass up and retightening. It did not help. Any ideas as how to raise the glass to be even with the roof?
Thank you.
Capt. Pete
Old 06-29-2009 | 12:26 PM
Did you try a panel initialization procedure? May be worth a try..
The roof opening panel motor initialization procedure must be done when repairs are carried out on any part of the roof opening panel system, including any time the roof opening panel motor has been removed from the roof opening panel assembly, a new roof opening panel motor has been installed or when a new roof opening panel assembly has been installed.
Turn the ignition to the RUN position.
For a new roof opening panel motor, press and hold the roof opening panel control switch forward until the roof opening panel glass moves to the full VENT position.
NOTE: Make sure the front door is open during this step.
Cycle the ignition from ON to OFF and then back to ON.
Within 5 seconds:
press and release the roof opening panel control switch forward.
press and hold the roof opening panel control switch forward.
Continue holding the roof opening panel control switch forward for 5 seconds after the roof opening panel motor stops moving to confirm this position to the roof opening panel motor.
NOTE: Only complete open and close motions count towards the cycle count. If the roof opening panel reverses during closing operations, perform the cycles with the roof opening panel control switch continuously held during the closing motions.
Release the roof opening panel switch and test the system for normal operation by checking the one-touch open, one-touch close, one-touch vent and close operations. Five complete cycles must be carried out for the roof opening panel motor to be correctly initialized.
If the roof opening panel does not operate correctly, repeat Steps 2 through 6.
__________________
Old 09-18-2020 | 03:22 PM
Stephen Raynish's Avatar
Default 2008 malin sunroof
Within 5 seconds:
__________________
Omg it works 2008 malin thank you sooo much took 10 sec.
Old 09-18-2020 | 07:16 PM
Glad it was a simple fix..
UB12
05-19-2020 11:54 PM
DanInSeattle
05-23-2015 03:21 PM
'97 f150
07-30-2009 01:03 PM
pyramid head
09-07-2007 09:17 PM
howeird
03-02-2007 11:14 PM
