ecoboost 2.0 misfires on cylinder 3
I have a problem with the Ecoboost 2.0 engine. Cylinder 3 misfires shortly after starting. After warming up the engine works well.
The problem has been going on for a long time, I visited several services, no help for now.
What has already been checked/done:
- replaced spark plugs
- swapped ignition coils between cylinders, the misfire is still on the same cylinder
- checked compression of 12 bar on each cylinder
- injectors replaced with new ones
I am sending a graph of parameters from forscan, after starting a cold engine . After a few minutes, the controller counted almost 100 misfires.
Any ideas?
Any ideas?
I did check the compression on cold engine but didn't check when warm. I figured out that the engine wouldn't work well on warm if there was a compression issue
Post the number when you have them,
I would also like to know the ECT (Engine Coolant Temp) when cold (is it the same as the IAT, Intake Air Temp) and when misfire starts.
