Ecoboost engine - turbocharger inquiry
Hi, all! Happy Friday!
1. I am trying to determine if the turbocharger on a 2016 EcoBoost engine is actually considered to be part of the engine block / head, or if it is not technically considered to be a part of either of these things.
The new Illinois Vehicle Code provides a 155 day, 500 mile implied warranty for fitness of use when buying a used car. 3 days after my purchase, the turbocharger went bad. It is only covered under this law if - the failure is a part that is considered to be the engine block, head, internal engine part, oil pan and gaskets, water pump, intake manifold, transmission, internal transmission part, torque converter, drive shaft, universal joint, rear axle, or rear wheel bearings.
2. Also, if a turbocharger goes bad, are there other things tht I should be imminently worried about either going bad or being bad, also?
Thanks so much for the help!
Jacq.
Jacq.
Jacq.
Jacq.
Hope your engine lasts.
