Fusion 2017 SE Battery issue "System off to save battery"
Old 04-15-2018 | 10:07 PM
fusion17's Avatar
Angry Fusion 2017 SE Battery issue "System off to save battery"
Hi Friends!
I have 2017 Fusion SE 2.0L Ecoboost purchased in September 2017. It was a sad day for me as and when I press the start button, car won't start and LCD display give a message ""System off to save battery, Please turn ignition off or start engine" followed by a message on the let side display of odometer panel saying "Dimming". This is the first time i faced this weird situation. I searched on google a little bit and found that a jump start would help restart the car. It works with the help of my friend. I am curious if someone with Fusion faced the same problem. The car is only 7 months old and I am really worried if this would continue. Please advise me the steps I should take. I'll greatly appreciate the time you would give to my request.
Old 03-22-2024 | 08:46 AM
eriknau's Avatar
This is an old post but maybe my solution will help someone with the same issue. I was getting this message and it turned out the 12V battery was coming to the end of its life and showing low voltage. It suddenly died (in a snow storm!) and I had to get a jump (look in the manual for how to jump, do not connect directly to the battery in the trunk!) and took it to the service center and they said I needed a new battery as it showed only 11V output.The battery was about 4 years old so that checked out, but you would think with all the messages the computer can tell you it would be clearer about the battery needing replacement.
robinsonb75
05-01-2024 03:06 PM
kylec1989
09-22-2023 05:38 AM
SteveRyan
06-13-2022 08:17 AM
Ka Mikalouski
07-31-2017 06:51 PM
Steelerdude1
06-25-2017 06:12 PM
Quick Reply: Fusion 2017 SE Battery issue "System off to save battery"
