removing stock radio
Old 03-31-2007 | 04:31 PM
317th's Avatar
Default removing stock radio
anyone know how to remove the radio? i want to install a amp to enrich the sound and add a sub... i dident get the audiophile package so i dont have the 6x9s in the rear deck.... and all the speaker wires are run through the frame... im not sure wear to begin to take apart the door panels....any help would be appreciated.
Old 04-01-2007 | 08:19 PM
goinstrong's Avatar
Default RE: removing stock radio
First - door panels have screws and fasteners - under armrests, in panel carpeting, under plastic caps, etc. that must be removed first. Then there are clips attaching it also. The radio may be easier to access from under the dash on the driver or passenger sides. Removing a stock radio might necessitate having a removal tool or knowing how the latches or attaching hardware hold it in. If you take a small inspection mirror and look in the back you may be able to figure how the latch works.
tombssebastian
12-12-2008 11:10 PM
NITROUSMIKEY
01-27-2008 11:12 PM
gtcoatie
01-25-2007 08:52 PM
luv2icefish
01-08-2007 11:46 PM
jgorz420
04-16-2006 06:13 PM
