Seat Belt Chime on 09 Fusion
Old 10-21-2008 | 01:12 PM
Papajo's Avatar
Default Seat Belt Chime on 09 Fusion
Hi
Is there anyway of disabling the seat belt chime on the 2009 Fusion SE V6?
Thanks for any help. Papajo
Old 10-21-2008 | 02:05 PM
Default RE: Seat Belt Chime on 09 Fusion
'BELT MINDER' DEACTIVATING/ACTIVATING
(Also in your owners guide)
Preparation
NOTE: The Belt-MinderĀ® deactivating/activating can also be carried out using the scan tool.
[ol][*]Apply the parking brake before deactivating/activating the safety Belt-MinderĀ®.[/ol]
[*]Place the gear selector lever in PARK (P) (automatic transaxle) or NEUTRAL (N) (manual transaxle).[/ol]
[*]Place the ignition switch in the OFF position.[/ol]
[*]Close all the vehicle doors.[/ol]
[*]Unbuckle the driver and the front passenger safety belts.[/ol]
Deactivating/Activating
NOTE: The driver and front passenger Belt-MinderĀ® are deactivated/activated independently.
[ol][*]Turn the ignition lock cylinder to the ON position (do not start the engine).[/ol]
[*]Wait until the safety belt warning lamp turns off (approximately 1 minute).[/ol]
NOTE: Step 3 must be completed within 50 seconds after the safety belt warning indicator turns off.For the seating position being disabled, at a moderate speed, buckle then unbuckle the safety belt 9 times, ending with the safety belt in the unbuckled state. After this step the safety belt warning indicator illuminates for 3 seconds.[/ol]
[*]Within 10 seconds of the safety belt warning indicator turning on, at a moderate speed, buckle then unbuckle the safety belt.
[*]This disables the safety Belt-MinderĀ® feature for that seating position, if it is currently enabled. As confirmation, the safety belt warning indicator flashes 4 times per second for 3 seconds.[/ul]
[*]This enables the safety Belt-MinderĀ® feature for that seating position, if it is currently disabled. As confirmation, the safety belt warning indicator flashes 4 times per second for 3 seconds, followed by 3 seconds with the indicator off, then the safety belt warning indicator flashes 4 times per second for 3 seconds again.[/ul][/ol]
[*]After confirmation, the deactivation/activation procedure is complete.[/ol]
bubble0304
10-18-2012 10:01 AM
Deauxx
04-19-2010 03:55 PM
heatershog
02-17-2010 09:20 AM
jjcast13
03-08-2009 01:42 PM
goat4x4
04-13-2007 06:09 PM
Quick Reply: Seat Belt Chime on 09 Fusion
