5.0 engine tapping
5.0 engine tapping
I bought the car non-running. The kid that had it before me flooded the engine with antifreeze while trying to put a larger throttle body and egr plate on. After this the engine started tapping.
I believe it has collapsed lifters, so I replaced them. Meanwhile I removed the heads and rebuilt them... regrinding the valve seats, replacing the valve seals, etc... I changed the oil and motor flushed the engine a few times hoping it would remove the remaining antifreeze. After all of this, it is still tapping.
Any suggestions on what to do next?
RE: 5.0 engine tapping
Are you sure the bottom end is good? Did not wash out the main bearings did it? May have a stuck piston ring from the coolant in cylinders. I would do compression check just to be sure. May have to fill cylinder with oil through plug holes to free up.
