Cylinder misfire in 2001 Mustang
Old 08-08-2009 | 11:54 AM
tunedin's Avatar
Default Cylinder misfire in 2001 Mustang
Recently the check engine light came on in my 2001 Mustang, which as 82000 miles. When I got the reading, it said there was a cylinder misfire ( in no. 3). There are new spark plugs (about 5000 miles ago). I wonder if replacing the coil would be the next place to go to solve the problem? What other sources of misfire shoudl be investigated?
Old 08-10-2009 | 04:51 AM
Use Common Sense's Avatar
Had the same issue with our 2001 with the 3.8L engine, but it only had 5,000 miles on it. Coil be coil pack or even thou basically new could be a spark plug (most common cause) as I have seen new plug bad right out of the box. Our issue was a bad injector causing the mis-fire. May or may not be your problem. Have you ever run any injector cleaner thru your system?
Old 08-10-2009 | 10:07 AM
Bullitt94's Avatar
Agreed. Try running SeaFoam in your tank to clean any possibly dirty injectors. If that doesn't work, try putting the old plug back in or a new plug in that position to see if it changes anything.
Old 08-10-2009 | 11:23 PM
tunedin's Avatar
I have not tried any cleaner yet - thanks for the hint
Old 08-11-2009 | 07:00 AM
You could also buy (about $10), or borrow a NOID light for testing for fuel injector pulses. You just disconnect the injector plug and the NOID light plugs into the injector plug. The NOID light will flash to the pusles sent to the injector. If no flashes, then the injector will be getting injection pulses sent to it.
haledonoem412
05-16-2009 05:20 PM
kilgore
07-05-2008 10:45 PM
miknwv
09-03-2006 05:16 AM
miknwv
09-02-2006 04:04 PM
Blueberry
09-02-2005 02:31 PM
