putting together a stock 302
Old 02-11-2013 | 11:09 AM
Happy302's Avatar
Cool putting together a stock 302
I have an 88 mustang that i has a 5.0 i tore engine down tp put all new seals and gaskets in it and im to the point of setting my push rods. it has hydraulic lifters and i was told you have to set them and someone else told me you just torque them to 22ft lbs what is true
Old 02-11-2013 | 12:02 PM
Welcome to the site
Their non adjustables. The rocker stud is shouldered and only need to be torqued. Torque ranges depending on who you ask,, may be 17-23, 18-24, but generally around 20lbs. Make sure the studs/nuts are lubed with engine oil when tightening..
22 is fine, overtightening can damage the nut/stud..
Old 02-14-2013 | 11:51 AM
Happy302's Avatar
Default can i use convertible motor mounts
putting in my engine and have to get new motor mounts. i found poly one and cant really afford them found convert mounts that are alot cheaper. just wondering if i can use these and if i have to change anything else
joeyj1954
08-08-2011 02:54 PM
astrapous
12-22-2008 11:13 PM
stoogesrule
02-23-2008 08:07 PM
NITROUSMIKEY
01-27-2008 11:12 PM
WildChild
05-22-2005 12:53 PM
