spring bump stops
RE: spring bump stops
First - did you add a rear sway bar? You should if you didn't. Bump stops (axle snubbers) can usually be found in any salvage yard cheap. But you might want jacking blocks - the metal cubes that jam between the spring coils. This still won't cure sway (momentum causing body roll in cornering).
