,taillight problem
,taillight problem
how you guys doing im having problems with my taillights on my 88 5.0 mustang i just bought, they dont turn on, they only twork when i hit the brake pedal, i thought it was my aftermarket radio after i installed it but i disconnected it all wasnt that, checked the fuses too they all look good, hopefully someone can help me out thanks
RE: ,taillight problem
Not common but anything is possible with the switch being bad.As for the tester you will have to find the hot+ wire for the tail light's at the rear light socket it may be brown (not shure)this is your + wire you have to trace.Make sure the light's are on when testing.And ground the black wire from your tester to the black wire in the harness.If the light light's up at the socket the bulbs are bad.
doberman
01-23-2015 05:00 AM
