Ford Performance Other parts make up a vehicle besides 'go fast' parts... discuss and review any of your other mods here.
88 Ford E150 302 AOD backfiring and running rich
Old 06-05-2011 | 02:38 PM
reedyd's Avatar
Default 88 Ford E150 302 AOD backfiring and running rich
The engine light stays on so can not get it to run codes. I have replaced ECC and Fuel pump relay. Changed high pressure fuel pump and the regulator. Changed spark plugs they were black. Changed some of the plug wires.
KOEO fuel pressure on rail is 40 PSI. KOER is 32 PSI.
Checked EFI module. Visually checked ECM and it looked ok.
Very clean and no smells.
Engine will exhaust smells pretty bad running real rich.
Any suggestions would be appreciated.
Old 06-06-2011 | 10:07 AM
Bullitt94's Avatar
Try new plugs, wires, and cap & rotor. May be poor/no spark somewhere and you areen't burning the fuel.
Eldridge174
02-06-2014 07:47 AM
SMCDonald93
09-22-2012 12:16 AM
drunkn_moose
04-23-2008 11:24 PM
xp coupe
04-16-2008 07:21 AM
Eco E150 1992 302 V8
08-14-2006 06:36 PM
