1990 ranger engine light rough idle
When I start up my truck, the truck will idle for about 2-3 seconds normal and then it will drop to a low 400-500 rpm rough idle and the check engine light will come on. Also, the battery gauge will swing to the right (drop to 9-10 volts). If I rev up the engine and hold above 1200 rpms, the battery gauge will go back to normal (12 volts). When it's warmed up, it's smooths out a bit, the idle will be at 600-700 rpm, engine light will stay on, and the battery gauge will go closer to 11 volts at idle but read normal 12 volts when I give it gas.
I have just had the head gasket replace, and water pump replace (they need repair). The above issue start about a month after these repairs. After the issue started, I had the battery replaced (it was old anyway) but none of the symptoms changed.
Any ideas??
1990 2.3L V6 XLT Ranger w/ 154,000 miles
Any ideas??
RE: 1990 ranger engine light rough idle
[sm=welcomesign.gif]To start with you should go to a place like autozone to get the codes read for free.[hr]This way it would give us a better idea what is going on.[hr]Also when was the last time it was tuned up?
Well for now i would check the vacuum hose's for crack's or see if they are disconnected.[hr]Also check all wiring to make shure all plug's are on tight.[hr]I all else fail's get the codes read and post them here.
Well, Autozone in Chicago is no help if you have a truck older than 1996. Had to go to a couple auto shops to find one that would be able to read the error on my truck. Murphy's Auto Parts were really nice and had no problem running the test a couple times to make sure. The code is 54. According to the book, ACT (air current thermistor). Sound about right?? Sorry told wrong....ECT (Engine Coolant Thermistor)
I popped the hood and located the ECT up by the top radiator hose on the front top of the engine. The thermistor was the issue cause when I touched it, it completely fell apart. My question is does anyone know how to get at the old thermistor to replace it. The space is so tight I can't get a wrench or socket in there.
