1995 Ford Ranger 2.3 will not start HELP!!!
Old 09-22-2013 | 09:25 AM
Erin Luzadder Robertson's Avatar
Default 1995 Ford Ranger 2.3 will not start HELP!!!
1995 Ford Ranger 2.3 will not start. Checked timing all is good, you can start it with no serpentine belt, it will miss but will start. As soon as you put back together with serpentine belt it will hit but not start. Any ideas what could be wrong with truck?
Old 09-23-2013 | 11:26 AM
bluewind's Avatar
The serpentine belt is driving the water pump, AC, Power steering and Alternator. One of these things is causing the trouble.
If you have no further indications pull the battery and the alternator and take them to a parts store like O'Reilly's for testing. It's free.
Also: how old are the spark plugs and wires?
Old 09-24-2013 | 06:35 AM
Spark plugs and wires are new, battery has good charge and alt is good! All pulleys are pulling when it is trying to start with the serpentine belt on, just will not start...
Old 09-24-2013 | 07:51 PM
greasemark's Avatar
Ok, the belt drives the a/c compressor, which is forever locking up and slowing down the starter, and it won't start. Or, something else is slowing down the starter; if the belt is removed, spin all the pullies, and see if anything makes a lot of noise or is frozen.
Otherwise, check that the belt isn't rubbing any wiring.
micsan
05-14-2013 08:13 PM
Lambough
09-20-2010 09:16 AM
scotts1964
11-26-2008 05:27 AM
NYCArmyWife
11-16-2008 12:29 PM
coco1971
11-11-2006 02:03 AM
Quick Reply: 1995 Ford Ranger 2.3 will not start HELP!!!
