2002 Power Window Problem
My '02 Ranger Edge driver side power window stop working.
Symptoms:
1) Driver side widows in the up position (closed)[:@]
2) Their is an audible click from the relay under the dash(next to the gas pedal) when the driver side power window button is pressed on the door.[:@]
3) The problem first appeared after the truck was warmed up, then it became permenant.[:'(]
I tried swapping around the relays from the passenger side (that ones working). I hate tobreak open the door panel to check the motor. Any suggeestion would help?
Symptoms:
