2007 Ranger Heater quit
Old 12-22-2010 | 12:37 PM
inspector73's Avatar
Default 2007 Ranger Heater quit
I've checked everything out on my 2007 Ford Ranger that I can think of. The AC works but not the heater. Any suggestions? Thanks
Old 12-22-2010 | 04:29 PM
Could you be a little more specific?
Does the blower work? Does the engine reach the correct operating temp?
Is the blower blowing only cold air? Is it blowing warm air out in the wrong place?
Thanks !
Old 12-22-2010 | 05:20 PM
The blower works...the engine reaches correct operating temp...the blower blows only cold air and not blowing warm air out int he wrong place. I can feel the heater hoses in the engine compartment but not getting any heat in the cab.
Thanks for your response.
Old 12-22-2010 | 05:37 PM
Correction..I can feel heat in the heater hoses in the engine compartment but not getting any heat in the cab.
Old 12-23-2010 | 03:49 AM
Are both hoses really hot? Does your heating system use vacuum controls or mechanical controls?
If both hoses are not equally hot ,suspect plugged heater core. If neither is really hot, thermostat or water pump.
If everything is vacuum controlled then possible blend door problem.
Old 12-23-2010 | 04:35 AM
Thanks...on our way out of town...will check when we get home and get back to you.
Happy Holidays.
ricknags
04-05-2019 02:39 PM
Fenderbender
12-15-2014 04:42 PM
AbNormal27
04-22-2014 09:33 AM
hfb1957
03-30-2010 04:07 PM
Jimbalyia
05-08-2007 08:49 PM
Quick Reply: 2007 Ranger Heater quit
