90 bronco II over heats. Heads???
I'm looking at a 90 broncoII for $200. It runs ok but it over heats. The guy tells me it needs heads. I'm not so sure. I'm going to buy it, but I thought someone might be able to give me some other things to check. It's a 2.9, stick, FI. what do you guys think could it be the heads? It doesn't miss, It runs & sounds fine.
Thanks
Thanks
RE: 90 bronco II over heats. Heads???
my 89 bronco2 did that and i just changed the thermostat and cleaned out the cooling system and i got a new radiator and radiator hoses and put in new radiator fluid it runs perfect alltogether it cost about 250$ it was simple to install
