97 Ranger Rusted up driveshaft
Old 05-31-2010 | 12:53 AM
chaddus's Avatar
Default 97 Ranger Rusted up driveshaft
So I'm trying to disconnect the single piece driveshaft from my transmission so I can get access to replace my clutch. The problem is theres a lot of general surface corrosion (rust) that's nearly fused the rear shaft to the mating flange where the bolts attach. I've sprayed penetrating oil all over it and have gone at it with a deadblow, but it won't budge. Any ideas?
Old 06-03-2010 | 03:49 AM
Use Common Sense's Avatar
If you haven't gotten it apart yet, try putting just a little heat to the flange and then take a small thin chisel and try driving it between the flange faces.
windh20
10-03-2007 10:46 PM
copper67440
08-01-2007 08:28 PM
FordF450
07-26-2007 11:49 AM
edgrenzig
11-12-2006 06:51 PM
edgrenzig
11-11-2006 11:39 PM
Quick Reply: 97 Ranger Rusted up driveshaft
