Air bag
Old 04-16-2008 | 04:48 PM
StoneRidgeTN's Avatar
Default Air bag
Ge..ntelmen,
I'll tell you what i tell the boys at my local auto store, when I need washer fluid....... I have a 2000 Ranger 4.0 4WD. I was Installing XM radio and i needed to disconnect the Pass airbag switch. (Did this thiis whit the Battery Connected, Shame on me). once i did this and connected it back the light stays on now. when i start the truck the light flashes a dozen or so times then stays lit. what have i done...............
Old 04-19-2008 | 07:45 PM
grease_monkey1965's Avatar
Default RE: Air bag
your probably going to have to get it cleared with a scanner
Old 04-19-2008 | 09:37 PM
Default RE: Air bag
Count out the lamp flashes..
It'll count out an LFC (light flash code) into a series of flashes.. Like 2 flashes, 'pause' and 5 more for a code 25.. Since you disconnected the passenger switch,when you start the truck, look at the PAD switch lamp (passenger air deactivation) and the PAD lamp should be 'on' along with the SRS lamp in the instument panel as the system proves out during the startup..
Old 04-27-2008 | 09:21 AM
ewgoetz's Avatar
Default RE: Air bag
I know on the mistang if the power source for the Airbag system is off for more than 30 min it will give a code off saying that it had lost power. Have to ahve it cleared. Not sure how it is done on the rangers. on a mustang you had to short out a connector on the passengers side.
makuloco2000
07-07-2024 10:30 AM
nivek2421
03-01-2019 12:12 PM
City Gal101
05-01-2012 06:02 PM
Pegger
09-26-2005 09:36 PM
reconwarrior
04-11-2005 03:11 PM
Quick Reply: Air bag
