Alternator Walkthrough?
Old 08-15-2006 | 04:21 PM
shlby123's Avatar
Default Alternator Walkthrough?
The alternator crapped out on my '00 Ranger...I was just wondering what the level of difficulty is of doin it myself, im mediocre when it comes to mechanical inclinations, and if there are any posted or well known walkthroughs on how to do this?[&o]
Old 08-15-2006 | 04:26 PM
94 4x4 ranger's Avatar
Default RE: Alternator Walkthrough?
Welcome What engine do you have?
Old 08-15-2006 | 04:41 PM
shlby123's Avatar
oh thank you! It's the 4.0 with an automatic! lol, i cant believe I left that out. Great to be here!
Old 08-15-2006 | 04:44 PM
Mulletman's Avatar
You can replace that alternator with basic tools and a little patience. It is not a bad job to do at all. If you run into any problems, reply to this topic.
Old 08-15-2006 | 04:53 PM
If it is visible it should not be that hard.I have a 3.0.But dont rember the 4.0[ul][*] Just disconnect the battery[*] Remove the belt[*] Disconnect the wiring[*] Take out the bolts[*] Replace the alternator[*] Replace the wiring[*] Replace the belt[*] Reconnect the battery[*] Keep in mind the way the belt goes before you take it apart also the wiring .If you are skeptical I recomend that you by a repair manual at the auto part's store.And now would be a good time to replace the belt.
[/ul]
[/ul]
[/ul]
Old 08-15-2006 | 05:09 PM
shlby123's Avatar
Alright, Im gonna give it a shot then! My girl just had the belt replace at a shop back in April so im hoping it's still good. But what is the most gentle way to take the belt off without damaging it? It's a big *** alternator and it's pretty visible! one of the 130 amp ones.
Old 08-15-2006 | 05:21 PM
Ok I forgot to tell you. By one of the smaller pully's you will see a small square.That you insert a ratchet extension (1/2 inch drive) in it and I belive you push it down to relese the tension off the belt.If you get lost on how to put the belt back on there is a sticker on the truck to show you the way.And make sure the belt is in on all the grooves before you start it.
Old 08-15-2006 | 05:30 PM
shlby123's Avatar
ok im gonna give this a shot! I wont have the new alt til Friday but I'll keep ya'll posted on whats going on and if I get stuck!! Thank you !!!
bluzzer
12-13-2018 09:56 AM
makuloco2000
12-07-2014 01:28 PM
dykzeulb
12-04-2004 02:24 PM
Lil_Turtle
05-18-2004 07:33 PM
Quick Reply: Alternator Walkthrough?
