breaks acting up
RE: breaks acting up
It's probably your rear brakes. Pull the drums off and check to see if you have an axle seal or brake cylinder leaking. If just a little brake or gear lube gets on the brake shoes, it makes the brakes super grabby.
well it is the rear only i think and i replaced the shoes and the parking brake cables and all the hard ware as well as turned the drums and that helps with the shuddering i also need to replace the o2 sensor
