A/C Issue...Compressor?
Old 09-18-2006 | 01:18 AM
apollo's Avatar
Default A/C Issue...Compressor?
Okay, first let me say that this is an incredible forum with good advice...so I am saying thanks in advance for all of my future posts!
On to the problem....
I tried to charge my A/C in my 95 2.3 4cyl with no luck. I bought one of those kits from autozone. Someone there was nice enough to help me. It wouldn't let me charge the system. I had it on MAX and it was blowing strong, however, the compressor wouldn't kick on. So, I did the following:
Check the fuse (was okay)
Checked the A/C relay in the "big" fuse panel under the hood....replaced it right there.
The guy suggested (which we did) unplug the connector from the accumulator from the switch and jumper the two terminals of the connector with a paper clip or jumper wire. If your compressor kicks on then the low pressue switch is not closing. It never kicked on.
So, I am stuck. Any ideas or suggestions for someone who is not terribly mechanically saavy, but wants to learn?
Thanks!
Dave
Old 09-18-2006 | 01:21 AM
apollo's Avatar
Default RE: A/C Issue...Compressor?
I read another side and someone said that it may be the "clutch switch"? Can this be the culprit, or do I just have a bad compressor?
Old 09-18-2006 | 01:36 AM
94 4x4 ranger's Avatar
It could be the clutch switch.[hr]You will need a test light or a meter to see if there is 12 volts there.[hr]This is the plug that go's into the front of the a/c compressor.[hr]Also make shure it is pluged in.[hr]It still might be the relay.[hr]And also when trying to put the a/c on make sure to push the fan button in on the fan selector.
Old 09-18-2006 | 01:44 AM
apollo's Avatar
There's my buddy! I knew you would be the 1st to respond
I don't have a fan "button" to manually turn on and off the a/c, just a dial. Even if I swapped the relay, it can still be the relay? Is this the clutch part I need?
http://www.partsamerica.com/ProductD...pe=431&ptset=A
If so, do I have to do anything, like remove the refreigerant? Clueless here...
Thanks!
Dave
Old 09-18-2006 | 02:01 AM
What i am trying to say is push the dial in till the a/c light comes on.[hr]That part look's like the high pressure switch.[hr]What im talking about is at the a/c compressor there are two wires that go in there is a plug there make shure that is pluged in and also check your power there.
Old 09-18-2006 | 02:53 AM
Dave you still there?
Old 06-02-2017 | 07:14 AM
Jymi Walker's Avatar
i have an 97 t-bird no 12 volts at compressor or low pressure switch. I bought a new CCRM from ford dealer since all relays are in ti that controls AC still no 12 volts anywhere. What am I missing? please help giving car to Daughter as graduation gift
milkshake
12-14-2008 03:22 PM
97F150SH
01-10-2008 02:10 PM
dieselman21585
07-23-2007 02:21 AM
Frank
10-31-2005 12:41 PM
hveatch2
07-21-2005 05:44 PM
