Catalyc Converter
Old 01-23-2006 | 01:51 PM
TROJN007's Avatar
Default Catalyc Converter
Has anyone had trouble with these, i have 97 ranger 2.3 and their is a terrible rattling coming from the converter. I was wondering if anyone has had this problem is their anything i can do besides replace the whole pipe?
Thanks
Jeff
Old 01-24-2006 | 08:13 PM
DangerRanger11's Avatar
Default RE: Catalyc Converter
I've got a 98 ranger 2.5 I4. I'm currently having the same prob. I replaced the exhaust system but it didn't help. My next step is the cat converter also. Just ordered one ($170). My new exhaust does sound sweet though. (Gibson single pipe performance cat back exhuast system)
goodson
Old 01-25-2006 | 06:48 PM
RNGMSTR's Avatar
The only thing that could rattle around on your cat. convertor is the heat shield. Use large hoseclamps and go around it, you will probably have to connect two togeather. I would buy enough clamps to put them both towards the inlet and the outlet. Your other option is to simply pull the loose heatshield off. It probably was a broken weld or two on one side and rattles when you hit bumps or when the engine is running at a certain rpm. You can start from the side with the broken welds and bend it back and forth untill it comes all the way off.
Old 01-28-2006 | 09:46 PM
Just replaced my cat and the rattling stopped. Mine was rattling during acceleration and as soon as I took my foot off the gas, it would stop. I spent way too much on a direct fit cat which had to be cut anyways due to my new exhaust. just get a universal cat and save some money.
DR11
Old 01-29-2006 | 11:02 PM
RNGMSTR's Avatar
Myself, I would either fasten or remove the heatshield that is most likley causing your problem before spending any $$$. Just my opinion, but why replace something that isn't broke?
393c stroker
03-01-2007 05:16 PM
975.030267ex
02-02-2006 11:14 PM
drew
11-03-2005 05:23 PM
drew
11-03-2005 04:25 PM
alleen7
04-07-2005 07:44 AM
Quick Reply: Catalyc Converter
