chirping noise and a/c
Old 06-27-2007 | 05:41 PM
woofan6's Avatar
Default chirping noise and a/c
99 Ford Ranger,4.0 I hear a chirping noise,sounds like it`s coming from back of engine.Also,when gas pedal is pressed a/c stops blowing out of vents,only comes out of defrost vent.I have changed serpentine and tensioner.A/C motor appears to run fine,also recharged a/c unit. Also have a noise from intake that sounds like a train.
Old 06-28-2007 | 07:57 AM
Use Common Sense's Avatar
Default RE: chirping noise and a/c
A/C output moving from vent to defrost vents when applying the throttle means that you have a vaccum leak in your A/C, Heat, Vent system. Check your vaccum cannister for a leak and all of your vaccum lines under the dash and under the hood that are associated with the Heat and A/C system.
makuloco2000
06-17-2014 12:30 AM
thepopeis1
06-17-2009 06:27 AM
No Harley Here
01-01-2008 09:59 PM
dustris
09-19-2007 02:14 PM
DKEYSER
02-05-2007 01:54 AM
