fan speed - only max setting
Old 08-01-2005 | 12:15 PM
frack's Avatar
Default fan speed - only max setting
My heater blower motor will only kick in when I put it on the max setting. It doesn't matter about any of the other settings as it works the same whether I am using the A/C or kicking out some heat. I have tried replacing the blower motor and the fan speed switch with no luck. Has anyone else had this problem? Any help is much appreciated. I have a 98Ranger XLT extended cab 3.0litre V6 auto. Thanks for any help...........Jason
Old 08-01-2005 | 12:47 PM
redfox's Avatar
Default RE: fan speed - only max setting
Check the ballast resistor. It is located on the passenger side, on the heater plenum chamber, next to the bower motor. The resistor coils are in the blower airstream inside the chamber.
Old 08-01-2005 | 02:04 PM
cctxfish's Avatar
Frack,
Redfox is right about the problem, but I'm sure they call it the, 'blower motor resistor' pack or assy.
Old 08-01-2005 | 06:26 PM
hockeyhitman69's Avatar
yes it is called a thermal resistor and is located right beside where the fan is
Old 08-01-2005 | 07:55 PM
Ramrod48's Avatar
Yeppers very common problem, has like 2 small 5/16 head screws holding it , an the wire pack just pulls off at the connecter , Any parts store should carry one , its like 10 min job !!!!
andy1865
09-30-2013 11:59 AM
Biscuit
11-01-2010 04:52 PM
alignmatt
05-03-2007 02:03 AM
Doyle
09-25-2005 07:32 PM
fordmann67
08-27-2005 03:03 PM
