Ford Ranger A/C (2003 - manual control)
Gentlemen:
My A/C is running all the time and no matter which air control setting I choose it will not shut off. When I select A/C or MAX A/C it works perfectly, but with all other settings it will run or cycle on and off depending on the fan speed. The compressor clutch is working fine and I've checked all the relays in the fuse panel under the hood with an ohm-meter as I don't know which relay is for the A/C). None of them are stuck on. Ideas????
phr3ak9x
10-10-2009 04:58 PM
GTP66
06-22-2006 01:33 AM
