Ford Ranger OBDI or OBDII
its a 2002-2006...its the more international version which its pretty much under the mazda b-series
File:Ford Ranger front 20080419.jpg - Wikipedia, the free encyclopedia
I believe just about all OBDII systems have an oxygen sensor after the converter where none of the OBDI systems I have seen have that feature.
Since the vehicle has a Mazda type set-up I would suggest you check with a Mazda dealer service dept. and they should be better able to suggest the better scan tool. It does appear to have the OBDII system.
if its 1996 or newer it will be obd2 which has a 16pin connector. The location of the connector link will be in the passenger compartment. obd2 mandated standardization of the connector and location of the connector.
The picture in not of a obd2 connector.
What is the tenth character of the vin?
what ever scan tool you get; get one that can display live data. A code reader can't, a scan tool can.
Do you want something that can display abs and airbag dtc, body and underfined codes or just powertrain codes?
I bought a launch c-readerVI and i am very pleased with it.
