Fuel filter with a check valve ?
Old 09-11-2008 | 01:37 PM
BillB's Avatar
Default Fuel filter with a check valve ?
Hi,
( 1999, 2.5L I4, auto/w OD )
Is there a replacement fuel filter with a built in check valve ??
I'm having pressure bleed off on sitting, which causes hard starting, and I am trying to sort what is bad. I found where I can clamp the fuel return hose shut to eliminate the pressure regulator. I haven't found a similar place to clamp a hose shut on the pressure side so as to sort pump vs injectors. If there is an aftermarket filter with a built in check valve it seems this would both allow bad pump determination and provide a temporary fix.
TIA
BillB
Old 09-12-2008 | 08:40 AM
Use Common Sense's Avatar
Default RE: Fuel filter with a check valve ?
If you're having fuel pressure bleeding off, then you either have a bad fuel pressure regulator or you have injector(s) bleeding which normally can be cured by a good cleaning. I would start with injector cleaning to see if that cures your problem.
jenmes70
07-29-2013 07:17 PM
Use Common Sense
09-12-2008 11:20 PM
kewiegand
10-27-2007 07:17 PM
JSR1024
06-18-2007 09:58 PM
gwald
03-26-2006 01:09 AM
Quick Reply: Fuel filter with a check valve ?
