fuel pump question FI
Old 01-16-2007 | 01:25 AM
Flattire Fred's Avatar
Default fuel pump question FI
i posted in the bronco section and am not getting and replies. 86 bronco II, i have two pumps, a low pressure pump in tank and a high pressure on frame rail. i would like to know the purpose of two pumps. is the low pressure pump for startup, idle, low rpm and does the other pump take over when accelerating. i ask because my rig will not start and i trying to diagnose fuel pump problems. i have spark and all that but it doesnt seem that fuel is reaching the cylinders. plugs are dry and don't have any gas smell after i turn the engine over. i can hear the pump in the tank when i turn the key and i have fuel to the filter before it reaches the high pressure pump. i have had problems with the rig dying at low speeds and when stopped. it always started back up no problem. now overnight it wont start. thanks
Old 01-16-2007 | 08:31 PM
sjwoody's Avatar
Default RE: fuel pump question FI
My 92 Explorer, 94 Ranger, and a 90 Ranger that I've since sold, only had a pump in the tank. Is the pump on the frame rail an add-on? I've never seen your set-up...but I'm just a shade-tree guy. Are you carbuerated or fuel injected? There's probably a screen type filter on the pickup side of the pump in the tank. I've seen those plug up as well. Perhaps you could "tee" in a pressure gauge at strategic points along your fuel line, (before and after your filter and frame rail pump) and see if you have a pressure drop somewhere. Just rambling thoughts.....
Old 01-16-2007 | 11:16 PM
cobra79's Avatar
That year had a low pressure pump in the tank and a high pressure pump on the frame rail. I would check and see if the inercia switch is triped. Have some one turn the key on and you should hear the pump in the tank run for 5 seconds the same for the one on the frame rail.On that model you allso have a relay mounted on the right inner fender under the hood. see if it clicks when you turn the key on.the relay may be green in color.Good luck
jozepy24
07-13-2019 06:21 AM
fordexpedition2006
04-21-2017 06:23 PM
Spaznaut
05-24-2014 03:10 PM
manicmachanic
12-13-2008 10:20 PM
shad9876
09-17-2007 11:52 AM
