Fuse box Diagram, Low range wont work?
Old 07-02-2006 | 02:07 PM
mikiemiky's Avatar
Default RE: Fuse box Diagram, Low range wont work?
My chilton book shows the inside fuse box but not showing any for your 4 wheel drive. I had a 94 explorer there was a power distribution fuse and relay box on the left inner fender up top toward the fire wall. these years also had a bad habit of the engagement motor going bad if not regularly(once a month) being engaged.
  #12
Old 07-03-2006 | 06:47 PM
AndrewMacks4.0's Avatar
thanks for the info, well my 4x4high works so could it still be the motor? and i found two wires, blue an green off the tranfers case where cut, the plug is broken that they are hooked up too... could that also be it
  #13
Old 07-07-2006 | 08:15 PM
94 4x4 ranger's Avatar
I dont know if you have figured this out by now.But I had the same problem on my 94 4x4 when I first got it.I found it was a easy fix!!! To get the transfer case to go into low range it must be in neutral not park not reverse or drive. 94 4x4 Ranger
  #14
Old 07-13-2006 | 01:44 PM
ya i have tried that, tried slowly in reverse also...
stptak
04-14-2013 03:48 PM
jake98989
02-19-2008 08:02 PM
cardinal33
01-15-2008 09:34 PM
renea_5441
10-21-2007 08:24 PM
biebrich73
06-30-2005 01:52 AM
