gasket/ clutch/?
Old 10-14-2006 | 10:10 PM
dngrrngr93's Avatar
Default gasket/ clutch/?
hello,
i think i have some problems
i have resently was trying to change my own oil but gave up and just had it done well they told me that my rear seal is leaking, my clutch feels like its gonna go soon and i was wonderin how much this will be ( just a guestamation im sure my machinecs labor is diff. from yours) umm and just how serious all this it umm if i fix the problem will my truck be good for much longer. umm it currently has 135272mi and i now just feeling a little difficulty shifting gear. the clutch pedal has to be pressed all the way down just to engage. umm i gues thats all. thanks for any suggestions
Old 10-15-2006 | 08:45 AM
94 4x4 ranger's Avatar
Default RE: gasket/ clutch/?
It all depend's.[hr]If you got the clutch changed at the same time it would be a lot less$.[hr]To replace the rear main seal the trans would have to come out any way.[hr]So get them both taken care of at the same time and save $.[hr]Ok the clutch is going bad is it loosing fluid?[hr]Because if it is it is not the rear main seal it is the clutch master it sit's in the bell housing behind the flywheel and will leak in the same spot.[hr]This is sometime's miss diaignosed for a rear main seal.
Old 10-21-2006 | 03:13 PM
jdm's Avatar
jdm
do you have keep adding oil every so often..? because if you do, then it could be the rear seal, but what i really think your problem is, is that your slave cylinder for your clutch is leaking. i had the same problem on mine, i just had to keep filling up the clutch fluid resovior. when u look under the hood the resovior will be right in the corner of the firewall and the drivers side fender. its pretty a pretty small resovior too. just add brake fluid to it to top it up, then go back in your truck and pump the clutch for a while, i think you will find that it will be easier to shift, and the clutch will feel a hell of alot better. but when you take the cap off the resovior, make sure you take the rubber grommet out of there before you fill it, don't just pour fluid into the grommet because it won't do anything.
Old 10-24-2006 | 03:16 PM
dngrrngr93's Avatar
hey, thanx for all the suggestions but i have already fixed the problem and now it works. umm a little unforgiving on the ol, check book but all is good
jmelees
05-17-2012 02:38 PM
cyberrkatz
07-07-2010 09:46 PM
skid2964
09-27-2009 02:29 PM
mike0179
04-25-2007 06:25 AM
JohnNetbee
08-01-2006 09:34 PM
Quick Reply: gasket/ clutch/?
