Is it hard to change a clutch in '97 ranger
The same Ranger with the 401 engine code needs a new clutch. How hard is it to change the clutch or better, getting the tranny out on one of these trucks? It is a 3.0 v-6 4X2. Time is not problem, I have air tools, tranny jacks, the clutch. I changed the clutch before on my '66 Falcon with its original 283, then with a 289 and now with a 351C. the ranger seems to have many little pieces parts that the Falcon just doesn't have.
RE: Is it hard to change a clutch in '97 ranger
thanks guys, it was not as hard as it looked! loosened the transmission and slid it back 6 or so inches, took the old clutch out and noticed leaking slave cylinder, replaced all parts clean flywheel and pressure plate with emery cloth and put it all back together, not to mention bleeding the system and it works fine.
