Idle Air Control Valve ?
RE: Idle Air Control Valve ?
Here's a pic of the IAC's location..
It's on the 'forward' portion of the plenium, bolted to the throttle body..
The whoo or moaning isn't all that uncommon.. Go to this link and follow the IAC unpluging..
http://homepage.mac.com/dogfriend/Ex...Theater14.html
[IMG]local://upfiles/6756/C6C6901639D149DFAF8D407543BE1F4D.gif[/IMG]
If this is what you hear..
To fix the problem, pull off the black 'vent' cover, pull out the pieces inside. You should find two felt filters inside. Carefully clean the filters so the air can move thru them easier. Assemble/snap the black cover back on the IAC. The noise occurs when the vent is restricted..
