Lower shock mount
Old 06-25-2007 | 02:20 PM
magnamn's Avatar
Default Lower shock mount
I have a 96 ford ranger, twisted off the lower shock bolt. can it be drilled out? it looks like a bolt inside a sleeve that is welded to the radius arm. Do I need a new radius arm? thanks
Old 07-15-2007 | 12:51 AM
danlunt86's Avatar
Default RE: Lower shock mount
You can weld a new bolt on. Otherwise you will have to replace the radius arm.
RH2OMAN
06-13-2007 03:15 PM
tnfritch
01-21-2007 01:05 AM
rustbucket89
12-04-2006 12:53 AM
pannwfn
04-10-2006 04:07 PM
Tony_8
03-17-2006 06:08 PM
