Needs compressor, but what if engine work follows shortly thereafter?
Old 07-03-2006 | 03:35 PM
daveranger's Avatar
Default Needs compressor, but what if engine work follows shortly thereafter?
I have a 92' Ford Ranger with 2.9 V6. It has 220,000 miles with original engine and transmission. I need a new A/C compressor, accumulator, and orifice tube. Already had hoses replaced. I have a couple questions.
Right now, A/C repairs are probably first priority now that Arizona summer heat is in full effect.
Now I am also hearing a rattle or ticking under the valve cover that cycles every seven seconds. The ticking seems to disappear when then engine has heated up.
Is this evidence of needing valve job?
I also need a quart of oil every now and then. There is no blue smoke at tailpipe. I can see at least one slow leak at the timing chain cover oil seal area in front of engine behind water pump.
It looks like I eventually might need valve job, or maybe even engine overhaul in near future. I just want to make sure the A/C repair cost wouldn't be wasted. It looks like the Chilton manual says that only compressor would need to be removed and positioned out of way with hose connections intact--for engine removal.
But what about timing chain/oil seal replacement? Would compressor need to be disturbed at all?
Thanks,
Dave
joelrz
01-26-2015 04:24 PM
euroexport
05-01-2012 09:55 AM
cubuffs
03-23-2008 01:22 PM
Luke 22
01-27-2007 04:26 AM
krosser
09-29-2005 04:53 PM
