Power Steering pump replacement problem
Old 07-08-2008 | 11:57 AM
gkferris's Avatar
Default Power Steering pump replacement problem
Hi everbody, new to the forum and right off the bat I need help.
I'm new to DIY auto repairs too, so maybe that's the bulk of my problem. Thing is, I've got this hand-me-down Ranger, it's a '94 and I'm proud to say it's up to 195,000 miles. The power steering pump is shot, and needs to be replaced as I'm refilling the reservoir every week at least.
Unfortunately, my vehicle has the 3.0 L engine, which I understand to be quite rare. None of the pulley removal tools I've found are compatable with this size of Ford engine, they only work with the larger engines. None of the parts stores have one for rental, I can't even find one for sale. Anybody know anything that might help me out?
Old 07-09-2008 | 02:24 PM
btexpress's Avatar
Default RE: Power Steering pump replacement problem
The 3.0 PS pump should not be that different from the others. Check with a Snapon or Matco tool dealer if you can find one. Some of these special tools are only available from a tool supplier or the manufacturer
Old 07-10-2008 | 01:17 AM
jr78's Avatar
Does that have the pully that bolts on the the hub that is pressed onto the P/S pump
jozepy24
07-13-2019 05:21 AM
jaypell22
10-16-2013 06:21 PM
bigat
03-07-2008 09:29 PM
tdrn
08-30-2007 07:32 AM
bsmith
12-25-2005 10:37 PM
Quick Reply: Power Steering pump replacement problem
