rear ABS need help fast
Old 10-20-2006 | 07:39 PM
Dis@ster07's Avatar
Default rear ABS need help fast
hey guys, i have been dancing around this at the dealership near me. here is what is going on:
98 ford ranger with rear ABS; the brakes are very touchy when i do hit them even a little bit the rear wheels will lock up. I do not have an ABS light on or a check engine like on. the dealership is not sure what is wrong and they want to charge me 85$ to put it on a computer and check. I personally feel this is fords problem and i should pay them nothing, and let me go ahead and let the suspence down but they don't feel that same way. i've changed the brakes, i've bled the lines and it did nothing for me. what can i do to fix this problem?
Old 10-20-2006 | 11:50 PM
94 4x4 ranger's Avatar
Default RE: rear ABS need help fast
Do they make noise?
Old 10-21-2006 | 12:24 AM
Dis@ster07's Avatar
they make some squeaking noises
Old 10-21-2006 | 03:19 PM
jdm's Avatar
jdm
pay the 85bucks and get it done right, they do know what they're doing at the dealerships and as much as you think its fords problem, just think, the truck is almost 10 years old already, things are going to wear out, and things are going to break, i do think it actually is a computer problem with the abs, so if you take it in, they put it on the computer, they can find whats wong instantly, correct it, and you can be on your way.
Old 10-21-2006 | 07:54 PM
I had this problem on my 94 I simply sanded the shoes and drums and reajusted the brakes and the noise went away and the lock up went away.
Old 10-21-2006 | 08:44 PM
Dis@ster07's Avatar
you think i should just redo them and see if that makes it go away?
Old 10-21-2006 | 08:56 PM
what brand shoe's are you using?
Old 10-22-2006 | 03:39 AM
Dis@ster07's Avatar
i'm not 100% sure i think i got motorcraft last time but i can't say for sure
is there a specific brand i should be looking for?
Old 10-22-2006 | 11:30 AM
I was hoping that you were not using cheap shoe's.
Old 10-22-2006 | 12:22 PM
Dis@ster07's Avatar
like i said i'm not really sure.. do you think its worth the money to try to get new drums and shoes before going to get the the CPU checked out?
Quick Reply: rear ABS need help fast
