Rear anti-lock brake light on
I just bought a 1991 Ford Ranger XLT for my son (94,000 miles). After I got it home, I noticed that the brake light (RED) and the Anti-lock light (amber) came on. They do go off sporadically and are off more than they are on, but what causes this and is there a simple fix? Thanks
RE: Rear anti-lock brake light on
There is one simple fix.[hr]There is a sensor in the rear end for the ABS system.[hr] Pull it out and clean it if there is any metal on the end of the sensor replace the fluid in the rear.[hr]After you install the sensor disconnect the ground on the battery for a few minutes to clear the stored code.[hr]If this does not work out for you you will have to det the code's read from the ABS system.
