Is she dying?
Is she dying?
My '97 Ranger has developed a case of no nuts. When I attempt a hill, she has very little power. Down shifting seems to make it worse. When I come to stop she wants to konk out. Not every time but more and more frequently. I have a few ideas but I am a sprinklerfitter not a truck mechanic. Valves? Bad gas? Tune up? Fuel filter? If some one has an idea I'd be greatful.
RE: Is she dying?
There's several things that could cause your problem. The first place I'dstart ischecking the computercodes - AutoZone will do it for free. Please let us know the results, and we'll try to help you troubleshoot from there.
RE: Is she dying?
Does your vehicle seem to run better when cold? Progressively getting worse the longer you drive it. Sound like you have a clogge cataylitc converter to me. If you can remove the O2 sensor from b4 cat and drive you will notice instant improvement if this is the case.
RE: Is she dying?
does your truck randomly shut down at stop signs and u said that it lacked power on hills I've seen somthing like this on toyotas.It almost sounds like a vacum problem. I could be wrong but hey its worth checking out what can it hurt?
