should radiator fan run continuously?
I have a 92' Ford Ranger with 2.9 V6. As long as I can remember, the radiator fan runs 100% of the time when engine is running, regardless of hold or cold weather. A mechanic said the fan should only run when it is hot
Is this correct for my make and model? I guess this what fan clutch if for?
Thanks,
Dave
Thanks,
Dave
RE: should radiator fan run continuously?
I also suspect that it is a sensor issue. To ensure that the fan will spin at the proper speed (preventing the engine from overheating) as well as to decrease drive to the fan when it is no longer needed is basically what your fan clutch does.
mama2clean
05-17-2010 07:09 PM
factory310
04-28-2007 06:23 PM
