starting problems
starting problems
hope you can help me,my dad has a 2000 ford ranger we've changed plugs,wire, coil, electric ignition switch and still does this---it will start maybe.drive it all day sometimes differant places starts fine then it won't start turns over but nothing. it can sit in driveway and you can start it shut it off wait 5 minutes won't start after awhile starts. 3.0 automatic,we also get a code reading 305-306 i think is injectors. thanks
starting problems
ok i unplugged the safty neutral switch last night and cleaned it,starting all day so far,don't want to drive very far and shut it off could that be the problem. it comes all at once and later will start
Usually, and I use this term loosely here, the neutral safety(range selector switch) can affect whether the starter will engage among other things it affects.
Am I correct in assuming you have a 3.0L engine with one coil pack ?
