Stereo Removal
Old 06-09-2009 | 10:07 PM
Wagney's Avatar
Default Stereo Removal
Anyone have good directions on how to remeve the Stereo...it's just not working any more CD's won't eject and there are some other problems I just want to replace it...
Old 06-14-2009 | 02:25 PM
P4trikk's Avatar
Ford uses a spring system to hold their radios in. You need a $5 tool (from any parts store) its a set of two "U" shaped tools with knitting needle looking ends, they fit into the four holes on either side of the radio- push them, in pull them away from eachother slightly and the radio comes out with little effort.
A junk yard might have a replacement OEM ford radio that will plug right in for as little as $10- Good luck!
Oh do a search for
" Scosche Dt1 Radio Removal Tool (Din) "
Old 06-25-2009 | 01:31 PM
BUGNUT's Avatar
I made a tool using a coat hanger. You need to make 2 of these, one for each side of the radio. Just make sure that the "U" is parallel and push it into each side of the radio slowly.
Old 06-15-2017 | 11:01 PM
Flwest05's Avatar
Default Ford radio removal
Chantelle
02-10-2012 12:34 PM
05WhiteEB
02-03-2006 10:08 PM
jidai
07-12-2005 02:40 AM
goldfingerrd
02-01-2005 07:26 AM
Foxy_72
11-08-2004 03:48 PM
