Time for me to make a decision: replace engine?
Old 04-28-2008 | 11:33 AM
daveranger's Avatar
Default Time for me to make a decision: replace engine?
I have a 92' Ford Ranger with 2.9 V6. It has 247,000 miles.
I have been monitoring these symptoms for almost a year now:
1. engine misfiring, roughness, valve train noise initially when I start truck. then it clears up after a few minutes.
2. #2 cylinder spark plug frequently goes bad. Porcelain insulator is vaporized or plug threads are wet from oil.
3. Just in last week, white and blue smoke out tailpipe for 5 minutes after truck has been sitting a while.
4. Coolant and and oil is disappearing rapidly.
Ok, is it definitely time for a new engine?
Old 05-01-2008 | 12:49 PM
odecastro's Avatar
Default RE: Time for me to make a decision: replace engine?
I hate to be the bad news man but you are right. Now it is just a matter of seeing how much an engine would cost you versus a new car. Especially if you are having any other issues with the vehicle it might be time to get rid of the 92'.
Old 05-02-2008 | 09:57 AM
daveranger's Avatar
And just the other day, I found coolant residue on the oil disptick and oil filler cap. So the engine is terminal.
I got a few estimates for engine replacement. The Jasper engine with labor is $4600.00. the mechanic I go to only trusts Jasper remanufactured engines.I think he would probably refuse to install anything else. Said he has had problems with all other brands except Jasper. But it will probably go over $5000.00 with tax and other engine related components that might need replacing.
-Dave
Old 08-06-2008 | 11:26 AM
K23aRanger's Avatar
DONT DO IT!!! Just do what i did, i went and bought a Hondak20a, bore'd it out, then dropped it in place. all in all. it cost about 2000. go to http://www.jspecauto.com/have fun
Jonathan Anderson
04-10-2010 07:14 PM
kglendale
08-16-2009 10:27 AM
Dworm
02-26-2009 08:37 PM
