Tranny acting up
Old 04-29-2007 | 07:25 AM
shortleg's Avatar
Default Tranny acting up
I'm a newbie to this forum, and I'm really not much of a mechanic, so bare with me please. I have an 03 Ranger 4x4 automatic. It seems like the transmission is having trouble shifting gears. Occaionally, the rpm's seems to go higher than normal before it actually shifts gears. The fluid level is fine. I have slightly less than 30,000 miles on the truck, it's due for transmission fluid change at 30k. I have done a fair amount of towing with the vehicle. I have been pretty good about turning off the over drive when towing, but have to admit I did experiment with leaving it in overdrive to see how it would go.
Years ago, I had a different vehicle that was having a similar problem. A mechanic friend advised me to have the pan dropped, clean out filings, tighten bands, and replace fluid. That did the trick back then. Is this still applicable on today's transmissions? Or just what should I do?
Thanks for any help.
Old 05-03-2007 | 03:56 PM
tomb1269's Avatar
Default RE: Tranny acting up
Have your computer checked for trany codes. The trans is a 5 speed auto and is controlled by computer vs the older trucks. Also do a filter and fluid change on the trans, when the pans down check for debris. PS other emissions devices can mimic trany problems...........
pup
08-20-2007 05:55 PM
94 loneranger
05-04-2007 11:40 PM
F250LOVER
05-23-2006 12:32 PM
MSTHTD1
02-24-2006 07:34 PM
anthony
09-11-2005 04:02 AM
Quick Reply: Tranny acting up
