trans light flashing
I can't figure it out. The trans in my 2003 4x2 ranger will go into "safe mode", I guess,usually when I first leave my house. It happened more frequently during the colder weather, but will do it once in awhile still. I usually can fix this by restarting the engine and it won't act up for the rest of the day. The truck has a 2.3L with 24K on it as well as the tranny. I did a motor/ tranny swap into a higher milage truck,123k, from a wrecked, salvage truck. One thing bothers me real bad, it seems to wind too long after you pass another car and when the engine rpm's come down it will upshift. I don't think it should do this. I have changed the fluid and filter to no avail.Also, it seems to go into gear with some hesitation hot or cold. It has remained in 2nd at a stop light 2 times which I'm uncomfortable with. It always seems mushy shifting.I really need some input to correct this,
Thanks to all
Thanks to all
RE: trans light flashing
I tried to use the computer from the salvage truck but the coded ignition key would not sync with it. You are referring to the computer in the cowl correct. I had the codes removed once before.The only thing it did however is kick the theft light on in the dash.
tomcat5
08-10-2021 05:10 PM
rodav8
07-02-2007 11:41 AM
italianjeremy
03-03-2006 10:59 PM
