Turbo kit for 98 ranger?
Old 09-06-2007 | 11:10 PM
tsi18psi's Avatar
Default Turbo kit for 98 ranger?
Does anybody make a turbo kit for a 98 ranger with the 4.0 v6?
Can i atleast find some manifolds that are flanged for a turbo?Flange style doesnt matter.I have plenty of turbos laying around with all diff. flanges.So if I can find some manifolds flanged for a turbo I could build the rest.I have intercoolers,boost gauges and boost controllers laying around as well.(I drag DSM's)
Thanks
Old 09-08-2007 | 11:10 PM
Use Common Sense's Avatar
Default RE: Turbo kit for 98 ranger?
There are no Turbo kits or anything that I am aware of. You'rebest bet is to use a header with a flange welded on it to mate to a turbo. Plus trying to find the room for smooth plumbing and an area that can take the heat. You'd be better off force-feeding it with a supercharger. That's more do-able.
Old 09-08-2007 | 11:16 PM
tsi18psi's Avatar
Thats what I figured.
I just thought since they made them for the old 2.3.Im pretty sure they did anyways.That maybe there was one out there.
You wouldnt happen to know there I could get some cheap or used headers at would ya.I dont want to spend alot of money for a mock up set oh headers.
Thanks for your reply
Old 09-10-2007 | 01:11 PM
I know that the 98 Rangers only came with the 4.0L OHV engine. However, the 4.0L SOHC is still a Cologne engine and may still retain the same exhaust bolt pattern at the OHV version. Easiest way to tell is to compate exhaust manafold gaskets. If the same, then EXPLORER EXPRESS sells headers for the SOHC that then may work. They are pricey since they are polished stainless. Also, I believe that Pacer, Edelbrock, Hedman and JBA also make headers for the 4.0L OHV.
http://explorerexpresscom.nationprot...roducts_id=728
Turbonator1
03-27-2018 02:02 PM
Jville808
10-21-2006 10:44 PM
Evo_jr
09-25-2006 01:24 AM
mustangsidewinder
01-23-2006 03:37 PM
stugots
10-19-2005 09:31 AM
Quick Reply: Turbo kit for 98 ranger?
