Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
My truck is slipping out of gear
Old 02-27-2022 | 07:49 AM
Kev19701's Avatar
Default My truck is slipping out of gear
My 05 sport trac started having this problem for a few months now. I noticed that this only happens when the engine is still cold. I'll let the engine run for about a minute or so, put it on drive and sometimes it takes a about 5-10 seconds to go in gear. pressing on accelerator for a couple seconds, and then suddenly lurch(shudder) forward.
Sometimes it engages smoothly from park, and as I start driving, it will slip out of gear again(foot on gas and I'm not going any faster despite the RPM going higher on the tachometer), then a couple seconds later; I lurch forward again. Has anyone experienced this issue?
Old 02-27-2022 | 11:39 AM
Might be a good idea to have the trans fluid level checked. When was the trans last serviced?
Old 02-27-2022 | 11:52 AM
Kev19701's Avatar
I don't think it's ever been serviced. I've had it for two years and it was one owner before that. It has 95k miles on it. But I will look into having the level checked and serviced. Thanks
Old 02-28-2022 | 03:47 AM
raski's Avatar
The most simple cause could be a clogged filter. Cold fluid would be more difficult to pass through than warm fluid.Also, by dropping the pan, you could see if any abnormal amount of debris has collected on the pan's bottom.
billyfish24
08-25-2021 11:10 PM
Expired
11-17-2018 05:06 PM
weighman
01-13-2011 08:54 PM
hellcatbyte
11-15-2010 08:12 AM
drjoeshmoe
04-21-2010 12:33 PM
Quick Reply: My truck is slipping out of gear
